Fuel Gauge Sensor Wire
Old Apr 15, 2013 | 10:00 PM
McChoka's Avatar
Car: '82 Z28
Transmission: TH-350
Axle/Gears: Posi
So since my fuel gauge is fried, I went and bough a new one tonight. Only issue is that, for the life of me, I can NOT find a wiring diagram for my car anywhere that includes the fuel gauge sensor sender wire. All I need is the color and approximate location of the wire. 82 Z28 automatic transmission.
Old Apr 16, 2013 | 02:48 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Fuel Gauge Sensor Wire
http://www.austinthirdgen.org/mkport...uges_part1.gif
Looks like a pink wire, Idk about that old of a car but i believe the cluster still has the 2 plugs in the dash where it slides into the pcb, you can find it there
Old Apr 16, 2013 | 10:37 AM
McChoka's Avatar
Car: '82 Z28
Axle/Gears: Posi
So I got it hooked up, but when I turn my car on, it sinks my gauge past full like too much power is being put to it. Ideas?
Old Apr 17, 2013 | 04:04 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
what ohm range is the new gauge?
Old Apr 21, 2013 | 10:43 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Full deflection on the gauge indicates a break in the circuit, i.e. disconnected pink wire.
Old Apr 21, 2013 | 11:48 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
I've always had an issue where a full tank always went way pass full, I just figured my tank sensor was out of range
Ghettobird52
Jul 5, 2024 11:18 PM
9192camaro
16
Feb 3, 2019 12:21 AM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
