please help me identify this connector
Old May 3, 2013 | 10:17 PM
Mpperry001's Avatar
Car: 1983 Daytona 500 Edition Trans Am
Engine: Carb 305
Transmission: NWC T5
Its a small box under the passenger side of the dash. The car is an 83 Trans am Daytona. Any help is appreciated. Thanks
Old May 4, 2013 | 01:48 PM
xdamagedx's Avatar
Car: 1991 Camaro RS being built
Engine: N2o Injected 350
Transmission: Reverse Manual Valve Body 700r4
Axle/Gears: 3.73 Torsen
Re: please help me identify this connector
http://www.austinthirdgen.org/index.php?pid=19
that might help, why though? if it aint broke, don't fix it
Old May 4, 2013 | 02:29 PM
Jeffs82TA's Avatar
has something to do with the check engine light. I pretty sure it is there to turn on the check engine light every 50k miles for cat converter inspection or something like that.
Old May 4, 2013 | 04:09 PM
Twin_Turbo's Avatar
that's called an E cell timer, is it a CFI car?
Old May 4, 2013 | 08:39 PM
Mpperry001's Avatar
Engine: Carb 305
My car is carbed. I though it might be the vss buffer box. The car had cruise control. I'm just not sure if this car has a vss.
Posted from Thirdgen.org App for Android
Old May 5, 2013 | 01:39 AM
Twin_Turbo's Avatar
Early CCC systems had it also, it will have a VSS
Old May 5, 2013 | 11:51 AM
Mpperry001's Avatar
Engine: Carb 305
Anyone have a diagram showing vss? I've looked everywhere and can't find one. Thanks
Old May 5, 2013 | 06:35 PM
Mpperry001's Avatar
Engine: Carb 305
Ok i found this picture of the 83 VSS. I'm doing a tpi swap and need a 2k vss signal for the computer. Does anyone know the pinout or which wire i need to tap to get that 2k pulse signal?
Old May 5, 2013 | 06:50 PM
Jeffs82TA's Avatar
You can't use that vss with TPI, buy a inline speedo cable VSS
Old May 5, 2013 | 06:57 PM
Twin_Turbo's Avatar
Old May 5, 2013 | 08:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The picture is of the lamp driver module.
http://tpiparts.net/inc/sdetail/7586
Old May 5, 2013 | 09:23 PM
Mpperry001's Avatar
Engine: Carb 305
Ok thanks for your help. I'll have order one up.
Old May 5, 2013 | 09:40 PM
Engine: Lb9
Transmission: M20
Np they have the best price on the retrofit vss
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
