Fog light fusible link location? help with fogs
Old May 4, 2013 | 11:07 AM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
89 trans am 305 tbi
I have been battling a fog light issue for a while now and could use some help.
I was reading the wiring diagram for the 89 t/a's and apparently the relay is powered by a red and white wire that leads to "fusible link Rust"
does anyone know where this link is located?
-I replaced the fog light relay, and i still have no power to fogs.
(however the relay clicks every time i press the fog light switch)
-I tested the power to the relay and i get a reading of -0.04
Same reading to the power feed wire to the fog light connector.
so now im wondering if maybe this fusible link is bad, and could use some help finding it, has anyone come across this link before?
below is the link to the diagram i used
http://austinthirdgen.org/mkportal/m...ody_wiring.gif
EDIT: the only fusible link i am aware of is the one next to the battery and that is good
Old May 5, 2013 | 04:30 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Re: Fog light fusible link location? help with fogs
Just pulled the fog light wiring harness out of an '86 Camaro. The fusible link was on the pigtail coming out of the back of the fuse block under the steering column. Hope yours is the same.
Old May 5, 2013 | 11:17 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
From the diagrams I have, it seems that the link is located under the hood on the driver side near the master cylinder. My wiring diagram shows 2 other links spliced together with the fog light relay link. The other 2 links go to the headlight door module. My diagram says "on light harness, near LH side of dash". I don't have an actual pic of it. My wiring diagram shows main battery power going thru connector C100(firewall connector next to master cylinder) into the interior to a splice that powers a lot of different items. From the splice, it goes back thru connector C100 to the engine compartment where it goes to the fusible link. So I'd say its around the master cylinder area(above it or below it) where the headlight door module is. It should be poking out of the harness and easily seen. Its a barrel looking thing with a wire going in and a wire coming out.
Old May 5, 2013 | 11:41 PM
Car: 1986 Iroc-Z
Engine: 355
thanks for the replies
seems like the link was an additional fuse attached to the bottom of the fuse block (i say additional because it is non existent in the fuse box diagram) but i managed to see that it contained the red and white wire that the diagram pointed out.
in any case it ended up being good, and i managed to pinpoint the problem on the fog switch. again thanks for replies guys.. i know a lot of people had no clue what i was talking about judging by the views/replies on the thread lol
PATRIOTIC1911
Sep 1, 2015 07:26 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
mustangman65_79
Aug 12, 2015 06:39 AM
