wiper wires
Old May 4, 2013 | 02:58 PM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Transmission: turbo 350
Axle/Gears: stock
wiper wires
My 82 z wipers had 4 wires to it my new 89 TA has 5 of which one is white(which powers wiper motor.)Earlier post records I did a steering column swap from the 82 Z. Wipers don't work......any suggestions? This may not be possible because the wire color orientation doesn't match up between the Camaro and Firebird connectors. Partially working now as previous owner cut the ground wire and rolled it back into harness taped off. Still have issues as colors are different and no pulse on 82 switch but they work on low so it is trial and error or call it good enough to pass inspection.
Last edited by stevek; May 6, 2013 at 11:02 PM. Reason: checked out original harness, found problem
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Randomtask2
Aug 26, 2015 03:34 PM
eddie jr
Aug 25, 2015 06:52 PM
slade5612
Aug 11, 2015 07:19 PM
