relay identification
Old May 4, 2013 | 09:17 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
I need to identify these relays in the image this was an 84 z28 high output carbureted so it didn't have an electronic fuel pump and i am pretty sure it didn't have a MAF so what are these?
Old May 7, 2013 | 10:17 PM
C.M.Jones's Avatar
Re: relay identification
Bump
Old May 8, 2013 | 04:19 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
I can't see the photos, but there are several relays that deal with everything from your head lamps to a/c; where is it located on the car? If you have the stock carb setup, it's unlikely that the relay is for the engine control or emissions systems.
Old May 11, 2013 | 12:44 AM
cxxm's Avatar
Car: 1984 Trans Am
Engine: 305 L69 (E4ME)
Transmission: NWC T5 1352-072
Axle/Gears: 3.73 (6HS)
I have been working on the same issue. I have a factory service manual and here is what I came up with after hours of research. I have a 84 carb'ed firebird that originally had a hood louver.
First here is your picture. I cannot see the wires, but it is fairly close to mine.
#1: MAP (Differential Pressure Sensor). There is also a Barometric Pressure towards the passenger side, along the top of back of engine compartment. It is also a MAP.
#2: Throttle Kicker Relay or Idle Speed Control (14039663). Wire Colors: blue, black, pnk/blk, brn/white, green. Five wires total
#3: Fuel Pump Relay (14078902). I know it does not make sense for a carb'ed car, but it is the only relay that matches the wire color on the schematics. The wire color is org/blk, purple/white, blk/white, tan/white. It is supposed to be tied to the fusebox: org/blk = 10 amp F Pump fuse & purple/white = 3 amp crank fuse.
I thought it was the ac control relay, but the schematics show those wires as pnk/blk, dk blue, dk grn, dk grn/white. Also, on the V8's instead of the ac control relay it shows the pressure cycling switch controlling the power to the a/c compressor. I also checked out headlight relays, but nothing matched the colors.
#4: Coolant Fan Relay: wire colors: red, blk/pnk, brn/wht, dk grn
#5: Electronic Spark Control
Here is a picture of what is on my car:
#2: Electronic Spark Control
#3: Coolant Fan Relay
#4: Hood Louver Vacuum Switch
#5: Throttle Kicker Relay or Idle Speed Control (14039663)
#6: Fuel Pump Relay (14078902)
Later....
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
