VSS and wiring
Old May 7, 2013 | 12:56 PM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Transmission: TH700R4
Axle/Gears: 9 bolt
VSS and wiring
89 firebird, carbed 305, no computer, and no computer harness (all removed), but still have the yellow VSS box. My question is where do i run the wires from the trans to, to get the speedometer to work? THANK YOU FOR ANY HELP!!
Old May 8, 2013 | 04:39 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: VSS and wiring
https://www.thirdgen.org/forums/engi...onor-need.html
This thread has some info on it regarding wiring guages after a swap, however the VSS wiring runs through the PCM then to the dash I believe. If you messed with the computer wiring, you may have shot yourself in the foot. You can convert over to a manual drive speedo with the link above however.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
Bryan F
Aug 27, 2015 07:28 AM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
