Lost fans and wipers after deletes
Old May 12, 2013 | 11:01 AM
motokid108's Avatar
Car: 88' IROC Z.
Engine: 305 TBI.
Transmission: T-5 5 Speed manual.
Axle/Gears: Stock 3.08's I suspect.
So i swapped out my exhaust system and in turn deleted the A/C and Smog pump. Now that everything is back together and on the road, I seem to have lost fans (both heater and cooling) and wipers. i replaced the fuses and still nothing. I live in Oregon so wipers are a necessity, especially since this is my DD. I know i have 4 plug sitting on top the motor, but i'm not exactly sure where they go. I know 1 or 2 went to the A/C, but not sure about the other two. Any ideas? Any and all help would be greatly appreciated. Thanks in advanced!
Old May 13, 2013 | 04:09 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Exhausting Work
Using a fused jumper wire apply power directly to the blower + terminal.
Did the blower run?
If yes, use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) to probe the blower relay pin A red wire.
It doesn’t matter what position the ignition key is in.
Is there power on the
red wire?
Happy Racing!
I Didn’t Wreck Last Week, The Track Moved
codeysabatini
Nov 10, 2015 04:07 PM
adelane
Sep 9, 2015 08:51 PM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
scottmoyer
Sep 7, 2015 07:06 PM
