Fog Light Plug but no Switch????
Old May 19, 2013 | 09:54 PM
rwerk91's Avatar
Car: 91 Camaro
Engine: LS1, LSXRT &102mm TB, Cam,225 Heads
Axle/Gears: 9" 4.10 w/31 spline axles
So I have what was an original 91 V6 RS(upgraded LS/M6). Seen photos from previous owner with fog lights. First did the 6 ever even come with fog lights? Main question is I have a 92 Z28 with fog lights I want to switch over to this one. Now when I pull the gauge bezel (which is a NO fog light switch bezel and no defrost) there are what looks to be what is the factory connecter for the switch. Could this run to the fuse box? I cant seem to find any plugs in the front end for the lights themselves. So where is this dash plug running to? Also has defrost connector behind bezel. GM run these connectors regardless of the added option? Hope the question makes since. Mainly just wanting the cleanest way to possibly run fog lights/ Thanks
Old May 19, 2013 | 10:04 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Fog Light Plug but no Switch????
Without being able to see it, I can only tell you that the harnesses were basically all-inclusive, regardless of options. So most likely you are seeing the switch plug (just need a switch now) and likely to have the light plugs down front (just need lights to plug into them) and the fuse put in if it was a separate fuse & not combined with some other thing that has a fuse already in there.
Old May 19, 2013 | 10:37 PM
rwerk91's Avatar
Car: 91 Camaro
Sounds good. That's what I was hoping for. Just gotta pull the switch and lights off the z28 now.
Old May 19, 2013 | 10:38 PM
rwerk91's Avatar
Car: 91 Camaro
Sounds good. That's what I was hoping for. Just gotta pull the switch and lights off the z28 now. Thanks
eightsixseven
Dec 16, 2024 01:50 PM
jaridjohn
Jul 8, 2024 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
