contimious rapid check engine light
Old May 22, 2013 | 08:29 PM
NotsosleepyZ's Avatar
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
I have new parts for the whole top end including cam, but would like the car running perfect before I put them on so I know if its a part I installed incorrectly or something I haven't touched, especially considering I will not be running the computer anymore.. but the check engine light comes on and flashes rapidly and wont stop. the car hasn't been ran in ten years there was an eight of tank of old gas I put in half a tank of 91 and mixed half a bottle of additive to help burn up the gas, any suggestions?
Old May 22, 2013 | 08:32 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: contimious rapid check engine light
Sounds like the prom is not seated correctly in the ecm or the ecm is faulty.
Old May 22, 2013 | 10:55 PM
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
ok well the comp will be eliminated anyways, its ccc, and I am putting a demon on it.
Old May 25, 2013 | 09:54 PM
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
yea I found a vacuum line that was unplugged so I plugged it back in and it seemed to fix the idle problem however, the check engine light is still flashing it seems to flash to the pulse of the engine idle
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
