how difficult are msd ignition to install
Old May 26, 2013 | 10:22 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
I have a carb on 355 SBC with around 400 horsepower. The car is a 86 IrocZ and I need more fire. I'm wanting a standard 6a msd system. Nothing too hi tech. I've never installed one I'm just wondering about the level of difficulty from 1-10. Does it consist of getting power to msd and to coil or is it more to it? Will I notice a cleaner burn and more power?
Old May 26, 2013 | 10:46 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: how difficult are msd ignition to install
The hardest part of installing one of them is finding what spot looks the best. It is probably one of the easiest installs you'll ever do.
Old May 26, 2013 | 11:04 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
basically, you run switched power wire, ground and line from distributor and line to coil. Like said above, mounting and making it neat is hardest part usually.
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
theurge
Aug 21, 2015 12:46 PM
tartagliaz28
Aug 15, 2015 10:59 AM
