converting my 1990 to carb with the chipped key a problem?
Old Jun 3, 2013 | 05:49 PM
mr.camaro's Avatar
Car: Red 86 Iroc-z / Black 90 Iroc-z
Engine: Mild 350 / Vortec L31
Transmission: TH700R4 / TH700R4
Axle/Gears: 3.42 / 2.73
Hey guys!
i want to convert my 1990 camaro iroc-z from 5.0 tpi to a carbed engine, what is the trick to get it running with the chipped key?? do i just leave the ecm and every thing should work?? thanks
Old Jun 3, 2013 | 07:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: converting my 1990 to carb with the chipped key a problem?
Originally Posted by mr.camaro
i want to convert to a carbed engine, what is the trick to get it running with the chipped key??
Once you have a carb, the computer is gone so VATS ( the chipped key ) doesn't work anymore, all you have to do is bypass the starter relay
Do a
Lots of info on carb swaps available on here
Old Jul 24, 2013 | 06:55 PM
pete0013's Avatar
Car: 86 iroc
Engine: 383 ci
Transmission: 700r4 Kevlar kit, non-lockup
Axle/Gears: 3.42 posi
Hey guys!
I have a column from my old 91 in my 86 with a carbed 350 ( when I got the 86 the key was broke off in the ignition switch.) had to spice wiper control( different between years) but the vats column works fine. Hope you had luck with yours
Last edited by pete0013; Jul 24, 2013 at 06:56 PM. Reason: Forgot to say 86 was carbed
Old Jul 28, 2013 | 01:58 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by pete0013
the vats column works fine with a carbed 350.
VATS column does NOTHING , because with a carb swap there is nothing looking for a input signal from the VATS module
which means having the chipped key ( or not ) is irrelevant.
Old Jul 28, 2013 | 07:02 PM
pete0013's Avatar
Car: 86 iroc
Engine: 383 ci
My point exactly
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Sanjay
Aug 12, 2015 03:41 PM
