Control power door locks via pc
Old Jun 12, 2013 | 07:41 AM
djjon76's Avatar
Car: '84 Trans Am
Hi all.
I have a relay board that is controlled by my pc.
Eventually I want to be able to use my smart phone to control the relays and these relays to control various bits of the car.
But to start off, how would I wire in an external relay to lock / unlock the doors?
But still keep the ability to use the normal buttons on the door?
Once I have this, I can then bring the pc board into the equation.
Hope this makes sense?
Cheers.
Jonno
Old Jun 12, 2013 | 03:12 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Control power door locks via pc
why not just get a key FOB set up as why even bring the phone into the equasion as if someone steals your phone they can steal your car
Hey dont get me wrong I think its a way cool idea personally but where did you get the idea from?
Old Jun 12, 2013 | 07:10 PM
djjon76's Avatar
Car: '84 Trans Am
Fair point...
I only picked on the doors as an example of how to wire in the relay.
I probably should of picked something a bit simplier
Old Jun 12, 2013 | 10:17 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
IIRC, the power door locks are a positive trigger. The 2 wires(1 for lock and 1 for unlock)are located at the driver kick panel. Cant remember what colors they are right off hand. You can wire up 2 relays to send out a positive pulse to operate the locks, then you can do your circuit board thing so you can use you phone to operate the locks. Wiring up the relays would be easy to do,
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
