what are the black and black/white wires under the dash?
Old Jun 13, 2013 | 09:56 PM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
I looked thru the austin thirdgen diagrams and cant find it. Its a black wire and a black wire with a white stripe, stuck together just like a 12v power strip.its dangling under the dash. The ground is the brown wire right?
Old Jun 17, 2013 | 07:28 PM
chrisD1023's Avatar
Car: 83 z28 camaro
Transmission: TH350
Re: what are the black and black/white wires under the dash?
I have an 83 Z28 and the wires you mentioned have been cut and taped up and are dangling from the bottom of my steering column. I wish I knew what they were for as well. I'm in the process of replacing the steering wheel and horn doesn't work, wondering if they are for that???
Old Jun 22, 2013 | 03:02 AM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
Well my horn doesn't work either, but my whole accessories circuit doesn't seem to be working. The fuse isn't blown, but it used to get blown often. Now it doesn't blow, but none of the accessories work.
Under the dash, right around the middle of the plastic trim piece that's close to the pedals, I found a small circular object. It looks like there was a black and black/white wire connected to it, seems to be a little bit of wire sticking out. No picture right now, since it's dark and I've been taking the dash apart a lot lately.
I have no idea what it is or does, it just looks like one of those circular objects you would find on a circuit board: http://www.reatechnologies.com/Images/board.jpg
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Aug 13, 2015 12:59 PM
