A different fourth gen camaro gauge cluster question with a twist.
Old Jun 19, 2013 | 01:32 PM
cw3adkins's Avatar
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
Okay guys, I have (essentially) a question in lieu of some newer technology and the electrical gauge cluster out of the 2001/2002 Camaro. I do know that a electronic signal is used required to output the speed on those gauges and typically it would be supplied by the ECM. I am wondering if it is possible to use a GPS module (such as the Cyberdyne module) to output the speed on one of the 2001/2002 clusters.
The only thing that I know about the Cyberdyne module is that Summit has the following posted information:
* Output 8k/16k pulses to match most speedometers
* Sample Rate: 10 Hz
Cyberdyne's GPS Module PDF
Veethree Instruments GPS Module PDF
If anyone can figure out if this is possible (and if it is, would it also control the trip/odometer?) it would be much appreciated!!
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
