Aftermarket Gauges
Old Jun 26, 2013 | 02:48 PM
86Base's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 383 Stroker
Transmission: stage 2 2004r
Axle/Gears: 3.55
Aftermarket Gauges
What size and type of gauges fit my 86 Camaro? what has to be done to install them, do they plug right in?
Old Jun 30, 2013 | 12:59 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Aftermarket Gauges
What gauges do you want to put in? You will have to make a custom plate if you want them where your speedo and tach is. Are they going into a A-pillar pod? Would need to know the gauges in order to let you know what has to be done and it depends on what you do as you might be able to wire them into your harness.
Old Jun 30, 2013 | 03:05 PM
86Base's Avatar
Engine: 383 Stroker
Axle/Gears: 3.55
Im looking at the classic thunder drilled gauge panel that has 2 3-3/8 gauge holes and 4 2-1/16 gauge holes and im looking at the auto meter phantom series gauges and getting speedo, tach, fuel, oil pressure, temp, and either boost or volt gauge
Old Jul 1, 2013 | 12:52 AM
6SIX6's Avatar
Car: 89 IROC
If you want to save some $$$ do your own panel as I did and it cost me arounf $35 to do it . Was pretty simple as all I did was use some MDF and then appoxied some mould plastic they use for hobby molds ( it matches the dash too ). Then took a hle saw and did the holes for the gauges
Old Jul 1, 2013 | 12:53 AM
6SIX6's Avatar
Car: 89 IROC
The pics of the templete in wood where taken as I was doing one for a friend
Old Jul 1, 2013 | 05:19 AM
86Base's Avatar
Engine: 383 Stroker
Axle/Gears: 3.55
That looks sweet, what kind of wiring was involved or did it just plug right in?
Old Jul 1, 2013 | 12:47 PM
6SIX6's Avatar
Car: 89 IROC
To be honest I dont have a pic of the back at the moment by I will see if I have one on my CPU when I get home. Wiring was pretty simple and it tucks between the gauges pretty good
69GTOby
Apr 18, 2016 02:34 PM
tommy z-28
Oct 6, 2015 10:58 PM
customblackbird
Oct 1, 2015 04:30 PM
Stryker412
Sep 20, 2015 06:59 PM
codeysabatini
Sep 20, 2015 11:36 AM
