Removing Air bag wiring and all components?
Car: 1992 Z28
Engine: 355
Transmission: 700R4, 2600 stall
Axle/Gears: 3.73 S60
I have my current project stripped down to the basically nothing except wiring and a few things here and there. I was wondering is it possible to remove the airbag computer, all wiring, all sensors/impact sensors ect and still have the stock ECM control the gauges without issues or is this a nightmare on its own? If its possible should i try to get the harness and components out in serviceable condition or just cut it out and make it faster?
I'm thinking this for a time attack car which is basically stripped anyways and thinking of ways to cut down a few more lbs.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Air Apparent
Yes once the airbag is removed you can remove all the other components due to the fact those components, and the ECM, are independent.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is Sliding On It’s Roof
Happy Racing!
1992 Trans Am
May 10, 2023 07:19 PM
