fuel pump help
Car: 90 RS
Engine: 305 for now
Axle/Gears: stock 2:73
fuel pump help
Im having trouble with my fuel pump on my 90 rs the pump would not run so i went to the relay in the process of checking for power i blew the fuse on the orange feed. Wire in wich i can not find the fuse so help with that would be geat but the only way i can get the pump to run is put power to the gray wire at the pump
Car: 90 RS
Engine: 305 for now
Re: fuel pump help
Is it on of the fusable links on the stud near the radiator ? Org wire i asume ?
There was power to that at first how do i test the relay amd what else would keep from getting power from relay to.pump
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: fuel pump help
It is a fuse in a fuse holder not a fusible link.
https://www.thirdgen.org/forums/tbi/...y-harness.html
Engine: Lb9
Transmission: M20
Re: fuel pump help
not all cars received test terminals a G or pigtails at the relay.
Car: 90 RS
Engine: 305 for now
Re: fuel pump help
I found the fuse thank u after replacing the fuse i have power on the org wire the pump will pule when u turn the key on nut wont run when engine is running no power to red or green when engine is running
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tighten The Pule Nut
You’re not supposed to have power on the red wire, or the “pule nut”.
But not having power on the green wire is a problem.
You have a bad connection from the fuse where it’s suppose to tie into the green wire.
Physically trace from the output side of the inline fuse to the junction point in the harness, usually located to the right, of the top of the right strut mount.
Happy Racing!
Spin Me This Week . . . I’ll Spin You Next Week
Happy Racing!
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
