Alternator Conversion
Old Jul 3, 2013 | 10:58 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
I have a 91 that Im converting from a serp drive to a v belt. I will be relocating from the driver side to the passenger side and going with the earlier alternator, from an 86.
My question is, can I cut and splice the old style connector to the harness or is there something more I need to do or know.
Old Jul 4, 2013 | 12:38 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Alternator Conversion
GM make a PnP adapter harness to convert old style SI Alt to a CS130 /144 that appears to only use 2 wires
http://forums.corvetteforum.com/1575549345-post17.html
so you should be able to do the reverse with the opposite connectors
Old Jul 4, 2013 | 12:40 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Most of the connectors for the CS alternators are four wire but will only use two of them and the wiring is the same as the SI.
S = a heavy gauge wire to the battery supply (horn relay)
F = not used
L = a small gauge wire that comes from the idiot light and energizes the alternator
P = not used
http://www.novaresource.org/alternator.htm
http://temp.corvetteforum.net/c3/zma...ternator01.htm
Linson
Oct 24, 2025 02:00 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
