VATS intermittent failure gremlin
Old Jul 8, 2013 | 03:23 PM
GRANDZINGA's Avatar
Car: '92 FIREBIRD
Engine: V6 - 3.1L - MPFI
Transmission: 5 speed manual
Axle/Gears: stock
Hello everyone. My issue is dealing with my VATS anti-theft module on my '92 Firebird. My VATS system has been intermittently illuminating the "Security" light and requiring the 4 minute wait with the key removed before it will start. So far the bird re-starts every time after the initial failure and the 4 minute clock expires.
I have done the following things so far:
*Starter Position Switch
*Starter Relay
*Ignition Lock with Matching Key
I know how to bypass the resistor portion of the VATS but do you think this would even help the situation since it did this with the original lock and resistor key as well as now with the new lock and resistor key?
Would I have to replace the VATS module to fix this major annoyance?
Thanks everyone!
Old Jul 8, 2013 | 04:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: VATS intermittent failure gremlin
If you would like the vats gone for good send me a pm, I can assist bye programing it out of the memcal in the ecm.
RS Reaper
Oct 17, 2018 07:52 PM
Grant2k
Apr 4, 2016 08:21 AM
Reid Fleming
Oct 10, 2015 09:56 PM
Fanatic1074
Oct 2, 2015 03:47 PM
sahlomonic
Sep 20, 2015 07:15 PM
