Strange Trans Am headlight issue
Old Jul 10, 2013 | 09:42 PM
arustedspork's Avatar
Car: 85 T/A
Engine: 6.0
Transmission: th350
Axle/Gears: 3.23 (something better soon)
I know there have been posts about the wonderful T/A headlights. Well I have a little bit of a problem and it's not the normal one.
One headlight works fine, but the other (drive side) only goes up 95% of the way and stops then the relay starts clicking (the fog light and head light on that side also blink) and it wont stop unless you screw it the rest of the way up.
Looking at a few things it seems like the motor is not getting enough power but I would have no idea why. Also I have used two motors.
Any ideas on how to fix this problem. (year is an 85)
Old Jul 10, 2013 | 11:11 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Strange Trans Am headlight issue
All those things you listed have in common ground G103, which I think is located somewere on the lhs of the radiator support. See if it's loose or dirty.
Old Jul 11, 2013 | 07:28 PM
Car: 85 T/A
Engine: 6.0
Transmission: th350
That did the trick thanks man, really appreciate that you have no idea who much of a problem that was.
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
red90IROCls1
Aug 25, 2015 06:56 AM
Fronzizzle
Aug 17, 2015 02:52 PM
mizz0313
Aug 12, 2015 06:45 AM
