[HELP PLEASE] Battery problems!
Old Jul 12, 2013 | 01:44 PM
delpiero99's Avatar
Car is always stored with battery unhooked
last year i baught a new battery because it was bad.. put that one in and the car worked fine
a week ago i wanted to take it out of the garage (finally) and as i suspected the battery was dead, so i charged it up but it never showed that it was FULLY charged, was just a notch before charged.
(i charged the battery when it was unhooked, does that make a diffrence)?
anyway, so today i hook the battery up and get in the car, turn the key to ON and i realise that:
-the battery guage shows battery is dead
-radio doesnt work
got out. unhooked the battery, put the charger back on and says that battery is almost fully charged
WHAT THE HELL IS HAPPENING GUYS
i dont wanna try starting it yet cause if i have to make my house smell like gas, id rather just do it once :P
Old Jul 14, 2013 | 10:18 AM
delpiero99's Avatar
Re: [HELP PLEASE] Battery problems!
HELP anyone?? :|
Old Jul 14, 2013 | 10:45 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
have the battery tested. if its bad should be under warrentiy and replaced. if its good insist on a new one anywas. next make sure the pos and neg I tight. I once had my car keep dieing mid drive from the neg beening lose. the neg beening lose, or bad ground, will casue the car not to respond.
does the dome light come on? if not its gona be a ground problem.
Old Jul 14, 2013 | 11:31 AM
delpiero99's Avatar
i dont recall if the dome light comes on, but i do remember the passenger light in the dash comes on.
Old Jul 14, 2013 | 12:21 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
have you done a voltage drop test?
there is instructions in this thread if your interested. it will take less than 5 minutes to do.
http://forums.superchevy.com/70/9388...h-the-exhaust/
Old Jul 15, 2013 | 05:09 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Charge Account
Batteries diminish in capacity when they are completely of near completely discharged.
That might be the reason it will charge to “one notch” away from full.
You might have a battery drain when the car is OFF.
Sometimes the under-hood or hatch light or motor does not turn off so check those easy ones first.
Then connect an ammeter in series with the battery.
If there is more than 50 milliamps there is excessive draw.
(You can use a small bulb such as a side marker bulb if you don’t have an ammeter.)
Disconnect the alternator wires to see if IT’S the problem.
With everything turned off and doors closed observe the current flow.
Pull the fuses one at a time, including the pump fuse near the battery, till you see the current drop.
That’s the circuit with the problem.
Happy Racing!
I Never Fight In The Pits . . . . . . . . . My Pit Crew Does That For Me
Old Jul 15, 2013 | 11:39 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Once you get the battery situation worked out, invest in a battery tender. Cheap insurance to not have to deal with what you have going on now.
Old Jul 18, 2013 | 10:41 AM
delpiero99's Avatar
Re: Charge Account
Happy Racing!
But why would I have battery drain if the battery wasn't even connected to the car and I baught it a year ago?
delpiero99's Avatar
What's that?
Old Jul 20, 2013 | 05:41 PM
delpiero99's Avatar
bump
Old Jul 21, 2013 | 02:56 PM
delpiero99's Avatar
UPDATE
so i go to start the car.. nothing..
at all
not even the usual ticking noise
im starting to think the battery isnt the problem, but my battery charger is
i mean the dash guage shows the battery is empty.. car obviously wont start.. but the car charger shows its full, and when i move the aligator clamps around theres barely no fluctuation on the battery charger, i think ill have to get a new one and see what happens!
Old Jul 22, 2013 | 04:22 PM
DARKmj16's Avatar
Engine: 305 tbi
take the battery.... to a.... PART SOTRE AND TEST IT! its free to test (advance/autozone/oreilys) they can also charge it (all free) they have a 1hr quick charge machine and they can test it after its charged. if the battery is going dead when not hooked up then it sounds like a bad cell in the battery, whichs kills the battery. the part store can test for that (again its all free).
Old Jul 22, 2013 | 09:18 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Take a volt meter and put it across the battery terminals and verify that the battery is indeed dead.
Hook up your battery charger to the battery and plug it in.
Then take a volt meter and put it across the battery. If the battery charger is working, it should read somewhere around 13-14 volts.
Old Jul 22, 2013 | 09:23 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
You have a bad ground on the battery. Trace the battery ground to the block and disconnect and clean the terminal and the spot where it connects.
Old Jul 22, 2013 | 11:42 PM
delpiero99's Avatar
ill try this tomorrow
if i remember well, the battery ground is right around here
is that the proper way to have it grounded?
(to whoever this pic is, clean engine bay )
Old Jul 25, 2013 | 02:13 PM
DARKmj16's Avatar
Engine: 305 tbi
wrong place. im not sure (if anything) is grounded in that area. the main battery ground (for my 1992 Camaro) is on the front of the passenger side head, behind and a little bit below the a/c compressor bracket. good luck getting to it. when I just recently took my heads off I had to remove the brackets and that's when I saw the battery ground.
there are 2 other points for ground, both on the back of the heads (1 driver side 1 passenger side)
Old Jul 25, 2013 | 11:06 PM
Devolont's Avatar
Car: 91 Camaro RS
Engine: LH6 5.3
Axle/Gears: 3.43 LSD
Grounds run all over the place. I installed new cables running for both ground and hot wires. If your battery sits in that part of the car (mine did) I put a ground wire there, where you have it marked. There are also grounds on the back of the driver side head, and I haven't seen a stock wiring in awhile but I put one on the intake of the engine. You can check for corrosion and even wire coating cuts or frays. If the resistance in the wiring becomes to high, it may not work well at all.
Old Jul 27, 2013 | 01:28 PM
delpiero99's Avatar
oh, cause the ground from my negative battery pole is grounded there and has never been changed... this car is 100% stock
Old Jul 27, 2013 | 01:33 PM
delpiero99's Avatar
The coating on the nevative ground is worn off at the beginning and at the end of the wire
Street Lethal
Apr 30, 2019 12:14 PM
GTAman
Mar 15, 2019 11:40 AM
mddaniel
Sep 8, 2015 05:16 PM
justin57
Aug 20, 2015 07:05 PM
