AC harness Wiring Help
Old Jul 21, 2013 | 05:01 PM
havacamaro's Avatar
Car: 86 camaro iroc z
Engine: 355 LT1 Full Roller
Axle/Gears: 9 bolt 3.73 posi
Newb here with a not so newb question. I have an 86 iroc, and the previous owner removed the ac system, evap, blower, condenser, compressor, and even chopped the harness at the firewall. I have acquired everything I need to get started on fixing it all to put ac back in the car. I have a few questions on the harness.
what do these go to?
also, when putting the fan on high, it shuts off, Is this a bad switch or something else wrong?
I'm pretty sure my car was a factory carb car, and my next question is how many vacuum lines should be coming out of the firewall with the harness, The new harness has 2 smaller ones, where as the old one that is chopped only has one bigger one. I hooked up the bigger one to the carb and everything seems to work ok inside the car. Thanks for any help guys...
Old Jul 21, 2013 | 06:47 PM
havacamaro's Avatar
Re: AC harness Wiring Help
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
