Oil pressure sensor wiring
Old Jul 24, 2013 | 11:19 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
My question is brought about because I am wiring in all new gauges and some of which require their own specific sensor to be used, i.e. a different sensor that is calibrated to work with their specific gauge.
I am currently running MegaSquirt that uses a slightly rewired stock TPI 90-92 engine wiring harness. I need to wire in a new oil pressure sensor in place of the old/stock oil pressure sensor. It appears that the stock oil pressure sensor was used as somewhat of a failsafe for the fuel pump, so if the relay failed the sensor could still power the pump. I do not care about keeping this particular feature so I am fine with doing away with that operation. So in order to wire in the new oil pressure sensor (which is the simple two wire type) I will cut/remove the orange power wire (that comes from the same splice of wires connecting to hot at all times fuel pump wire) or the grey wire (which is also power that comes from the fuel pump relay). One of those wires I would just leave for the power. Sound right?
Old Aug 30, 2013 | 10:50 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Oil pressure sensor wiring
Here is the diagram: http://austinthirdgen.org/mkportal/m...ine_wiring.gif
It appears is if the oil pressure sensor is only a type of fail safe and I should be fine in removing the stock sensor in favor of my aftermarket gauge's unit. Just need to remove it's old hot wire (orange specifically). Anyone care to chime in?
Old Sep 3, 2013 | 05:09 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Chime Time
Right.
You can eliminate the
orange wire and the gray wire that come off the stock pressure switch.
When cutting them out make sure you do it at their tie point only so you won’t cut the desired parts of the circuit.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
89GTAOz
May 16, 2020 09:31 AM
9192camaro
16
Feb 3, 2019 12:21 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
