Wiper Issue
Old Sep 2, 2013 | 08:42 AM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Wiper Issue
I tore down my steering column to fix my turn signal issue and now my wipers don't work. I did install a new multifunction lever as well. Everything is plugged in, I can't seem to figure out what would cause the wipers to quit. I'd like some ideas of what to look for before I go digging back into the harness under the dash.
Old Sep 3, 2013 | 05:15 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Rain Pain
With the wiper unit unplugged, key in the ACCY position, and the wiper switch in the HI position, use a voltmeter or test light (the type for testing for voltage, not a continuity tester) to probe the pink, dark green, gray, and purple wires.
Which wires do you have power on?
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Bubbajones_ya
Jul 6, 2024 08:32 PM
MM2Robinson
Oct 1, 2017 09:16 AM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
scottmoyer
Sep 7, 2015 07:06 PM
