turn signal help.
Old Jul 25, 2013 | 02:46 PM
IROC-Z123's Avatar
Car: 88 iroc-z
Engine: 350 tpi
turn signal help.
when i use my right turn signal it blinks two times on the outside and that's all. but the signal light above my gauges never shuts off. doesn't blink just stays on. any advice would be appreciated. thanks:help :
Old Jul 29, 2013 | 04:53 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Turn Of Events
First check all right side bulbs, to make sure they are the correct type, and installed correctly.
A common mistake is people installing 2 filament bulbs 180° rotated.
Some crazy symptoms have been reported doing that.
Now once you know all the bulbs are OK,
use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) key in the RUN position, turn stalk in the right position, probe the dark blue wire out of the column.
Is there power there?
If no, you need to get to the switch, probe it at the switch and if still no power replace the switch.
Happy Racing!
They Want To Put HOW MANY TV Cameras In My Car?!?!?!
Prodigious
Nov 7, 2020 09:23 AM
Fronzizzle
Mar 18, 2019 08:29 PM
dibella989
Sep 1, 2015 04:12 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
