Need help. turn signals.
Car: 87 Iroc-Z28
Hey fellows,
Prior to this everything was working.
Yesterday morning(Defogger and stereo on):
No turn signals.
Yesterday afternoon(Just stereo on):
Exterior turn signals - all work (front, back and side)
Interior indicators - right works but not left.
Last night(Headlights and stereo on):
No turn signals (Hazards worked)
Today, I went to see what the matter was and with key on the turn signals worked(not left interior). I then turned on parking lights and t/s slowed way down. So then i started the car and with the T/S or hazards on, I turned on the stereo and blower on, and the idle slowed way down.(barely hold on)
Could this simply be a flasher or the switch, or am in for some wiring time.
P.S. I did have issues with T/S before but tighten down the switch in the column fixed it.
No turn signals.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Turning The Tables
If you’re trying to say the turn signals get too slow or stop when you have accessories on, the cure is an electronic flasher.
The left dash indicator not working is probably a burned out or loose bulb.
Happy Racing!
They Want To Put HOW MANY TV Cameras In My Car?!?!?!
Happy Racing!
db057
Aug 11, 2015 10:11 PM
