Couple of gauge cluster questions
Old Jul 30, 2013 | 07:44 PM
Beater79TA's Avatar
I'm getting ready to wire in some new gauges and want to make sure I have a couple of things correct since I'm not finding the answers readily on the wiring diagrams.
1. Turn signal and high beam indicators: does the harness wire provide power or ground to turn the lights on?
2. Check engine light: same question: is the signal from the ECM ground or power?
The rest of the signal wires for each gauge are easy to identify as are options for overall power and ground for the replacement gauges.
Old Aug 5, 2013 | 04:50 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cluster Fluster
The stock harness of course provides those things you mentioned.
Are you asking the question because you plan to replace a harness?
If no, you don’t have to worry about the
Service Engine Soon light, signals or ☼ indicators.
Happy Racing!
“Help” Me Into The Wall This Week, I’ll Just “Help” You Into The Wall Next Week
Old Aug 5, 2013 | 05:08 PM
Beater79TA's Avatar
Re: Cluster Fluster
Replacing it all with aftermarket gauges and wiring LED's in for the turn signals, high beam indicator, and SES light so I want to hook them up correctly.
If I'm reading the diagram correctly, the turn signals and high beam indicator are a 12v signal and the SES light gets ground from the ECM. But I'd like to confirm this before wiring it all in and finding out its all reversed.
Old Aug 6, 2013 | 05:01 PM
NINÅ's Avatar
Transmission: 765R4
Cluster Fluster
Originally Posted by Beater79TA
…….the turn signals and high beam indicator are a 12v signal…….
Correct.
…….the SES light gets ground from the ECM.
Correct.
Happy Racing!
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
