88 Iroc Parasitic draw??
Old Aug 4, 2013 | 11:27 PM
Joes88Irocz's Avatar
Car: 88 Camaro Iroc-z
Engine: 5.7L 350
Hi i have a 88 iroc with the 5.7 TPI engine and it has a problem holding a charge i beleve the battery and alternator are good i also did a parasitic draw test and its within limits???? what is going on!!!
Old Aug 5, 2013 | 07:01 AM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
Re: 88 Iroc Parasitic draw??
What is the parasitic draw you measured?
Old Aug 5, 2013 | 03:25 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
You need to confirm this before doing anything else.
Old Aug 5, 2013 | 09:07 PM
Engine: 5.7L 350
i measured 10.1 MA but i don't know whats going on because now i started it and took it for a 2 hour drive and its been starting since ill have to see what it does after sitting overnight maby it just needed a deep charge?
Old Aug 5, 2013 | 10:44 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Anything over .05 amps is considered a draw.
Old Aug 6, 2013 | 12:41 AM
Engine: 5.7L 350
ok so should i start pulling fuses until it drops?
Old Aug 6, 2013 | 04:28 PM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
10mA parasitic load (0.01 amp) is not going to cause the battery to drain over a short time period. It would take months to drain the battery at that level of draw (assuming the battery is of typical capacity and not defective).
So, if your parasitic load truly is 10mA that is not the root cause of your battery going dead overnight(?) or over a week, or even over some months.
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
deracer
Apr 11, 2016 12:04 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
