Question for computer guys!
I have a 91 camaro and i have a corvette lt1 ready to drop in. I also have a 95 camaro fuel injection system. Would this work on my engine and would i need a computer burn to run it efficiently?
Thanks for any input fellas!!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Question for computer guys!
It is a LT1 swap question so should asked be here
https://www.thirdgen.org/forums/ltx-lsx/
Yes
What is the question?
If you install a LT1 into anything you need the LT1 computer and wiring.Nothing from the 91 engine management electronic works with the LT1
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You'll have to customize the cars wiring so it will connect to the LT1 harness so that everything works as it should ( Vats, Hot at all times, Switched Power, ect.... ) You might need a custom PCM - or 'tune' - to run the LT1 but that will depend on what Tranny/Rear end you use and how you build the motor.
