Issue with Painless coolant fan relay
Old Aug 14, 2013 | 10:02 PM
NuklearFusion's Avatar
Car: 1987 Trans Am
Engine: L98 350
Axle/Gears: 373
A friend of mine installed a Painless coolant fan relay a couple years ago and as of tonight, it stopped working. I have absolutely no clue on how to properly test this with a multimeter. When I select "DC mA" on the multimeter, touching the sensor (negative on negative, positive on positive) that is sitting in the water pump actually powers on the fans! If I set this to any other setting on the multimeter, nothing happens. I am trying to find out if I have bad wiring to the sensor or if it is a relay causing this. Any comments or advice? Thanks in advance!
Old Aug 14, 2013 | 11:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Issue with Painless coolant fan relay
Originally Posted by NuklearFusion
touching the sensor (negative on negative, positive on positive) actually powers on the fans!
Assuming you have a 2 wire sensor ,
if putting a jumper between the 2 terminals in the sensor connector makes the fan run , then the sensor is kaput and you need a new one.
A "bad" relay either is on full time or doesn't work at all.
As yours is switching the fan on and off you can assume it is fine
Old Aug 15, 2013 | 09:02 AM
Car: 1987 Trans Am
Engine: L98 350
Axle/Gears: 373
Thanks Vetteoz. The sensor is a two wire sensor. When I use the multimeter on it, I am not bridging the positive and negative with the multimeter terminals, just trying to get a reading off of them. When I do this and the ignition is on, the fans do kick on. Is it the multimeter causing the bridge even though I am not intentionally bridging it?
I thought that this was supposed to be "Painless", lol.
Old Aug 15, 2013 | 05:54 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Could reasonablely assume that on a low Mv scale there is enough current passing through the DVM to trigger the relay.
If you wanted " less pain " you could replace the 2 wire switch with this style
http://www.racerpartswholesale.com/p...n_Accessories2
and just run a single wire from the relay to it as done with the stock setup
Old Aug 15, 2013 | 09:18 PM
Car: 1987 Trans Am
Engine: L98 350
Axle/Gears: 373
Thanks vette. I'll bypass the switch for now until I get the replacement switch from Painless.
Old Aug 15, 2013 | 10:17 PM
Car: 1987 Trans Am
Engine: L98 350
Axle/Gears: 373
I feel like such an idiot. My thermostat got stuck, no wonder why the fans were coming on with the multimeter. Thanks for the replies!
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
Bstrang6
Sep 8, 2015 04:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
