Firebird will crank up and run but will shut off after running for a while
Old Aug 4, 2013 | 07:17 PM
dgbsire's Avatar
Car: 1983 pontiac firebird
Engine: 2.8l v6
Transmission: 5 speed
Axle/Gears: unsure
i am new to this page i just bought a 1983 firebird it has the 2.8l HO v6 engine 2 barrel carb it has the 5 speed transmission. thecar will crank up and run and drive fine but after about 5 mins of driving the car will sputter and jerk and shut of and will not crank right back up but if i let it sit for a little while it will crank right back up what could it be?
Old Aug 4, 2013 | 07:18 PM
dgbsire's Avatar
Engine: 2.8l v6
Axle/Gears: unsure
Re: Firebird will crank up and run but will shut off after running for a while
the car will idle fine for forever
Old Aug 12, 2013 | 04:37 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Grounded Bird
After it stalls while driving, turn the ignition off and pull over.
Open the hood and operate the accelerator pump by hand.
Does the accelerator pump squirt fuel into carb when you do that?
Happy Racing!
I Didn’t Wreck, The Track Moved
Old Aug 15, 2013 | 10:57 PM
Trinigoalie's Avatar
Possible fuel issue.
Old Aug 16, 2013 | 09:00 AM
racerx520's Avatar
check your fuel filter...when it shuts down and sits for a while, the debris in the filter is probably settling
bryan623
Mar 22, 2021 06:43 PM
Caspar
Jun 19, 2016 11:19 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
squiggy2
Aug 9, 2015 09:30 PM
