1984 T/A signal lights and back up lights
Old Aug 19, 2013 | 09:29 PM
RogerHale's Avatar
Car: 1984 Trans am
Engine: 305 H/O
Ok so I bought my 1994 T/A it wasnt running. After two simple fixes it runs great distributor and a battery. needs some body work and more interior then anything but for 700 bucks I gotta ttop 305 5 speed. But the only problem keeping it off the road is my back up lights and my signal lights. My back up light do not work at all nothing. But my left sig light blinks sooo slow blink 3 mississippis blink. And my right sig light just stays light up and the grren arrow in the car does not come on as the left one does help idk were to start.
Old Aug 21, 2013 | 03:59 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 1984 T/A signal lights and back up lights
Originally Posted by RogerHale
1984 T/A signal lights. my 1994 T/A.
Which is it?
Read
https://www.thirdgen.org/forums/tech...formation.html
Old Aug 21, 2013 | 04:01 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
But my left sig light blinks slow my right sig light stays light up
the grren arrow does not come on as the left one does help .
Are all the bulbs know good and tested as working.
If we knew what trans you had we could tell where to find and check the backup light switch.....
Old Aug 21, 2013 | 06:44 PM
RogerHale's Avatar
Car: 1984 Trans am
Engine: 305 H/O
Yes a changed them all it speed up the blinking very lil tho but for the reverse still no lights i went and got the switch that plugs in the transmission but its pouring the rain if that dont help i guess im going to be digging wires all day
Old Aug 21, 2013 | 06:47 PM
RogerHale's Avatar
Car: 1984 Trans am
Engine: 305 H/O
And the switch is on the drivers side an its a 5speed if you could tell me what kinda transmission i got would be great im still learning huge amount
Old Aug 22, 2013 | 07:08 PM
RogerHale's Avatar
Car: 1984 Trans am
Engine: 305 H/O
Ok so i just put the switch in and still no lights but i noticed when i pluged it upmy electric fan stoped working put it in netural fan would start back? Wiring is messed up i guess
Old Aug 22, 2013 | 07:15 PM
RogerHale's Avatar
Car: 1984 Trans am
Engine: 305 H/O
And its an 84 my phone loves to change it for some reason
Old Aug 26, 2013 | 04:38 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Turn 2 Learn
First check all bulbs, even tho new, to make sure they are the correct type, and installed correctly.
A common mistake is people installing 2 filament bulbs 180° rotated.
Some crazy symptoms have been reported doing that.
If the above is OK, an electronic flasher should solve the problem.
That might be a burned out bulb or bad socket.
Happy Racing!
If You’re In Front Of Me DON’T Slam On Your Brakes Just Because Someone At The Head Of The Pack Is Spinning
colton_carlson
Mar 8, 2019 12:21 PM
tnrednneck
Aug 13, 2015 08:57 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
