Starter Wiring Question
Old Sep 1, 2013 | 04:32 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Engine: 90-95 ZZ4 Crate 350 TPI
Transmission: 700R4 4spd Automatic
Axle/Gears: 3:73
Removed and replaced my starter on my IROC...took a look at the wiring and had a mental picture. Removed the starter support bracket. Wasn't sure if there was a harness ground wire there or not. During what I thought would be a simple removal, I had to remove the Y-Pipes...worked late last night. I picked up this morning and got the starter in, the black grd wire is on the solenoid. I vaguely remember that there were two wires that accompanied the positive cable to the solenoid orange and red...
I have a spare wire and it looks orange, but it also could be a ground wire. I tried to look at Haynes manual and it isn't giving me a clear picture of the wiring. Tried to go on Mitchell but it's a membership site. Can someone clear this up?
Afternoon board, I found a wiring diagram but not too sure what I am looking at. I really need someone's help on this drawing a blank. My gut's telling me it's a ground. Maybe it's on the bracket mounting point on the engine block, but I don't see any evidence of it being there. The eyelet is large diameter (9/16) Bolt. The upper starter support bracket is a 9/16 bolt...
Old Sep 3, 2013 | 05:11 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Getting Started
They go to fusible links, therefore need to be on the hot side.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Sep 8, 2013 | 09:08 AM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Re: Starter Wiring Question
Thanks Nina, appreciate the help...it fixed it...
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
redmaroz
Aug 16, 2015 11:40 PM
