Radio problem
Old Sep 4, 2013 | 10:27 PM
TheIgnitious's Avatar
Car: 82' Z28 Crossfire
Transmission: Turbo 350
Radio problem
I've had a reoccurring problem with multiple radios in my 82 Camaro. I have had to rerun a constant wire, and I thought I had it fixed. But it then began to work randomly or not at all, basically what it had been doing. So I ran test wires straight to the battery... And somehow my antenna set up was running as a ground? It seems to have shorted out both my head units so they do not play.. And comments, advice, or fixes? Is there a way to fix the set up? Or do I need to purchase another one? (Pulling antenna set up tomorrow)
Old Sep 7, 2013 | 01:09 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: Radio problem
Your antenna is supposed to be a ground, that's what makes it work. Actually, if you have a weak signal you should clean up the ground on the antenna.
I used to run a car audio shop way back when and now I wire fire chief trucks and limos. I bet your problem is a blown speaker. When a speaker is blown, it acts as a dead short. The factory amp can't handle the current, so it burns out.
The only way to test for a blown speaker is to remove it and measure the impedance at the terminals WHILE slowly pushing on the cone. You will see the meter go to infinity or -- depending on how your meter reads.
Good luck!
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
g.l.mos
Aug 22, 2015 12:02 AM
