brake light
Old Sep 14, 2013 | 08:09 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
brake light
not the one on the back of the car, the one on the dash, i always set my handbrake when i park, but lately after i release it, light stays on i imagine the little prong the plug...... plugs on to is broken off, anyone got a fix, messed with it a bit, thing is touchy as all hell
Old Sep 16, 2013 | 03:25 PM
Tinbender59's Avatar
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
Re: brake light
pictures ???
Old Sep 16, 2013 | 04:47 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Them’s The Brakes
Yes it might be broken off allowing it to touch the body ground.
Replace the switch.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Old Sep 16, 2013 | 08:18 PM
kmcn47's Avatar
Transmission: 5spd
Re: brake light
switch? its a little tab on the lever with a plug on it no? and my trans tunnel is carpeted how would it ground out? pics? of the brake light on the dash? im just gonna un plug it, hell i don't need it i know when i set the brake haha
Old Sep 21, 2013 | 10:17 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: brake light
On my car, this was caused by the electrical sensor in the proportioning valve. Apparently I have a bad valve, leaky lines or some other issue that caused my "brake light" to stay on in the dash. I disconnected the sensor and the light went a way. Now, I do lose brake fluid, I need to fill it about every six months but I'll be damned if I can find the leak...none of the fittings are "wet" so it can't be a big leak.
Old Sep 23, 2013 | 05:25 PM
NINÅ's Avatar
Transmission: 765R4
Them’s The Brakes
You might be losing it in the rear drums, if equipped, and it will look dry because of the small amount, and the camouflage of brake dust.
Also it doesn’t always come out of the fitting end.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Old Sep 23, 2013 | 06:03 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: Them’s The Brakes
Happy Racing!
I have four-wheel disk, not sure if this will have the same issue or not.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
