gauges go out when i turn headlights on
Car: 1985 camaro berlinetta
Engine: carb'd lg4 305
Axle/Gears: 3.08's sonn to be 3.73's
i have a berlinetta so my gauges are digital. whenever i turn my headlights on the speedo and the tach goes out what the heck... i need help
Car: 1992 Z28
Engine: 5.0 Tuned Port Injection
Axle/Gears: 2.73 posi
Re: gauges go out when i turn headlights on
Might be a stupid question but are your dashlights dimmed all the way down?
Car: 1992 Z28
I'm guessing you also checked your fuses. Have you done any wiring work on it recently?
no i havent done any wiring lately and i checked for any shorts and te only fuse blown is the ecm fuse... but i can still drive it
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
If you've tried to adjsut the rheostat dim control **** on the side o fhte headlight pod and nothing changed than there is a problemn with the DIM circuit. Could be a problem at the pod, could be the wiring,... but it's most likely the Light Module has failed.
do you know where i can buy the light pod and how much would that be
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 11, 2015 10:11 PM
