Is this killswitch idea possible, or am I just fantasizing?
Old Sep 18, 2013 | 12:16 AM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
Now that I've started putting lots of money into my car I've started thinking about installing some form of killswitch but I want to make it a little more different than the typical flip switch route. Basically what I was thinking was due to my car being a gta with the steering wheel controls would it be possible to create a 'code' and punch in a certain sequence of the buttons on the steering wheel to enable the engine to be engaged when you turn the key but won't be able to start otherwise?
Old Sep 18, 2013 | 12:24 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: Is this killswitch idea possible, or am I just fantasizing?
I was looking around, and while I Couldn't find anything about sequences of buttons to use as a killswitch, I did see one idea I really liked. Wire your defrost switch to be a killswitch. Didn't have any diagrams to go with it, was just an idea, but I liked it. I do know it's possible to use button sequences stuff like this, I've read about people doing it. I just wouldn't know where to begin.
Old Sep 18, 2013 | 12:29 PM
fervernt's Avatar
Im actually really tempted to try something like this myself on my formula. I have an extra switch panel floating around from a base model with a switch for foglights. Since I have no foglights on my car a blank switch that blends in perfectly is exactly what I need. This could be really fun, thanks for getting me thinking!
Old Sep 18, 2013 | 01:01 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Hopefully you guys have basic aftermarket car alarms to start with, otherwise they can just sit there quietly tearing apart your car.
Kill switches are nice and make it almost impossible to steal but if I were to add anything to the car concerning theft it would be a extra siren inside the car and a battery backup for the alarm system.
Old Sep 19, 2013 | 06:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Basically what I was thinking would it be possible to create a 'code' and punch in a certain sequence of the buttons on the steering wheel to enable the engine to be engaged when you turn the key but won't be able to start otherwise?
Some thought required
There are any number of switch / keypad circuits you can build but they still either have to interrupt something through a relay
( starter?) or generate a required signal , say fuel enable like the factory VATS does .
Time permitting any starter interrupt is easily bypassed by running a wire direct from the battery to starter solenoid
( don't park in dark alleys ) which is why the factory system also disabled the fuel supply by taking out the injectors
Old Sep 30, 2013 | 04:50 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
‘Kill’ The Thieves
Here is a schematic of a system of pushbuttons which must be pushed in the correct order to activate the ignition or any device on the car.
The system automatically resets when the car is shut off.
This schematic shows a ‘3 digit combination’, however there is no limit to the quantity of digits, you simply add more relays and pushbuttons or any type of momentary switch(es) to the circuit.
You can even eliminate carrying you car key by incorporating the required resistor into a relay - a plus for those modifieds that don’t need steering/shifter locks.
(It’s generally recommended to use automotive relays with built in diodes.)
You can use solid state relays if you want.
Happy Racing!
If My Engine Has An Illegal Part, And The Inspector Doesn’t Hear It, Does It Make A Sound?
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
