header questions please help !!
Old Sep 21, 2013 | 06:15 PM
789roby789's Avatar
Car: 1986 Camaro Sport Coupe
Transmission: 700-R4
Hey I want to purchase some headers and get rid of the old exhaust manifolds I have a carbd. 350 SBC and I would like to know division just bolt these headers on to the existing exhaust pipe outlet? ? Or add piping of some sort??Check out this item I found on eBay: http://pages.ebay.com/motors/link/?n...d=181164683389 please help me guys
Old Sep 21, 2013 | 07:33 PM
tsires's Avatar
Car: 1990 Camaro RS
Transmission: Manual 5 speed
Re: header questions please help !!
Not to many Headers are CARB certified. I have the EdelBrock headers and they were a pain to fit. If you have A/C you defiantly will want to use a Heat shield on the A/C housing where the headers fit to passenger side. Also if you have stock heads with strait spark plugs be ready to do some yoga to change them.
Old Sep 21, 2013 | 07:52 PM
789roby789's Avatar
Thanks ! And for my straight sparkplugs what would I have to do?
Old Sep 21, 2013 | 10:13 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Being from California, you need CARB approved headers. There are only three that I know of...
Edelbrock TES, Hooker 2055 and I think Dyno Don's. Of these, the Hooker and Dyno Don's are the best.
For plugs, accel makes a set of "shorty plugs" that are 1/4 of an inch shorter than standard plugs but the p/n escapes me at the moment. I run the Hooker 2055's and got a set of heads with angle plug ports on them which help a little with the plugs. Basically I don't have to disconnect my headers to put the plugs in and out of the car if I need to.
Old Sep 21, 2013 | 10:26 PM
tsires's Avatar
Car: 1990 Camaro RS
I agree, The shorty plugs are the only thing that helps but if you have angle plug heads that is the ticket! also be sure to use shields for your wires or they will cook at the headers. you may also want to look into a shield for your starter or a mini starter. I went through two starters before I bought a mini starter.
Old Sep 21, 2013 | 10:29 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Oh yeah, forgot about the wire shields, melted plug wires suck. You'll need a heat shield for the starter, just the wrap stuff is what I use.
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
