Need some info on an aftermarket alarm
Old Sep 30, 2013 | 02:31 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
I've been taking out some interior pieces of my 88 camaro and I found a little black box that says Clifford magnetic resonance sensor. I have no idea what that means. There is a 3 way switch wired to it, one direction is momentary, the other just standard.
My question is, what does this system do, and what is the relevance of the switch? Should I worry about removing this or disabling it? I'm converting the car to carb so there's a lot less wiring needed. Though that switch could make a good fuel pump switch if I don't need it.
Old Oct 1, 2013 | 06:47 AM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: Need some info on an aftermarket alarm
The sensor is a shock sensor and the switch is a valet/programming switch for the alarm. Follow wires to the alarm brain and remove all of it careful not to cut factory wires. The module will be a white or black box that says Clifford on it most likely with 2 white plugs, 2 red wires and one black wire should be run to the battery from the alarm and a siren under the hood, those should be removed as well.
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
tmellott89
Oct 14, 2015 02:06 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Eric-86sc
Sep 28, 2015 11:37 AM
