HVAC fan selector switch broken/stripped
Old Sep 30, 2013 | 07:42 PM
RavageTheRoad's Avatar
Car: 1991 RS
Engine: L69?
Title says it all, about a week ago the fan speen **** stopped working. It no longer clicks into place, it just spins around and doesn't turn on the blower. Any way I can fix it or at least rig up a temporary solution until I can find a new selector unit or fix the problem the right way? Car is a DD and I desperately need the defrost in the morning and when it rains.
Old Oct 1, 2013 | 03:20 PM
Car: 1991 RS
Engine: L69?
Re: HVAC fan selector switch broken/stripped
bump
Old Oct 7, 2013 | 04:36 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Welcome To The Fan Club
Without feeling it I can’t instantly tell you if it’s the plastic **** which is stripped or something inside.
Pull the **** off and try a Vise Grips on it.
Now can you turn the blower on?
If yes, epoxy the **** on using an epoxy made for metal.
The repair will be stronger than stock.
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Old Oct 7, 2013 | 09:09 PM
Car: 1991 RS
Engine: L69?
Hmmm... thank you, I will try that, although I can still feel light "clicks" when it gets to the positions it it is supposed to be in so maybe it's inside? I'll see what happens with the vise grips.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
Sep 3, 2015 04:21 PM
