Weird code 33/34 issue
Old Oct 9, 2013 | 06:08 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Guys, Upon a light cruise, all of a sudden I get codes 33 or 34 and the car strats sputtering and bucking then it goes away. On the scanner it appears that when this failure happens the MAF values lock in place, sometimes high sometimes low. I am trying to check the wiring from the computer to the MAF sensor, changing the MAF (swapped out with an old one, no change / have a new one on the way). Already checked the relay's. Can you guys make any other sugestions on poossible solutions? Thanks!
Old Oct 10, 2013 | 07:47 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: Weird code 33/34 issue
those codes reference the MAP not MAF
Cornholio7979
Sep 20, 2018 02:31 AM
Cleotiz
Jan 6, 2018 08:56 PM
mdtoren
Aug 23, 2015 12:52 PM
CORV3TT3
Aug 23, 2015 11:26 AM
mdtoren
Aug 16, 2015 05:45 PM
