Not your typical headlight motor question.
Old Oct 9, 2013 | 09:10 PM
soul.justice's Avatar
Car: 1985 Firebird Trans Am
Engine: 305 4bbl
Axle/Gears: 3.08
I rebuilt my drivers side headlight motor a while back out of several carcasses from the JY. I've had a problem since where every ten seconds after the headlight shuts, the motor still tries to turn. Any ideas why?
Old Oct 19, 2013 | 09:41 AM
Engine: 305 4bbl
Axle/Gears: 3.08
Re: Not your typical headlight motor question.
Bump
Old Oct 19, 2013 | 05:44 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Just a hunch, but it might be related to your headlight module. Might be worth a shot to swap it out and see if you still have the issue.
Old Oct 20, 2013 | 01:52 PM
Engine: 305 4bbl
Axle/Gears: 3.08
I didn't think the older birds had the module
Old Oct 21, 2013 | 06:52 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
i have never messed with the early ones but going from the diagram looks like your switch may not be working when down. there are switches that tell when its up or down and you will have to look with a meter and see
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 19, 2015 01:36 PM
