are gauge clusters engine specific?
Old Oct 10, 2013 | 12:59 PM
mjk1210's Avatar
Car: '83 TA
Engine: GM Performance 350
Axle/Gears: the slowest off the line
I saw an gauge cluster (looks identical to mine) for sale that specified it was for a v6 car. I have a v8. Always was a v8. I really can't imagine that the cluster would be specific to a v6 or v8 but just wanted to ask here first.
This is for an 83 Trans Am. so 82-84 cluster with all the gauges, not idiot lights.
any ideas?
thanks
Old Oct 10, 2013 | 07:38 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: are gauge clusters engine specific?
the tachometer will be off since you have two more cylinders.
Old Oct 10, 2013 | 09:24 PM
mjk1210's Avatar
Car: '83 TA
I can swap tachs from my old cluster and it should work correctly right?
Old Oct 10, 2013 | 09:36 PM
zenish's Avatar
Engine: 305 tbi
i assume that will work.you will also need to change your water temp and oil senders to ones for guages.
Old Oct 10, 2013 | 09:44 PM
mjk1210's Avatar
Car: '83 TA
They already are gauges. Cluster I am looking at is identical to mine. Always had gauges in the car. Looks to me like swapping the tach should fix the tach problem and all else is just gonna plug in and work fine then.
if anyone else has any knowledge let me know.
Thanks!
Old Oct 10, 2013 | 11:32 PM
mjk1210's Avatar
Car: '83 TA
Thanks!
Old Oct 12, 2013 | 10:59 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I think that the v6 and v8 speedo is run differantly.If not mistaken the v8 carb would have a vss buffur or somthing like that and the v6 is run off the ecm getting info from the spedo.at least the later modles that were tpi v6's
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
