im stumped
Car: 1987 Firebird Formula
Engine: 355
Transmission: Borg Warner 5 spd
Axle/Gears: 3:43
im stumped
ok ill admit im no genius at all when it comes to wiring and I am lost I am trying to convert 3.1 harness and make a 350 engine swap harness out of it i got some of it figured out but I cannot figure out the fuel pump it has me stumped help please!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: im stumped
ESP don't work on the internet
Using what induction ?
Using what ECM ?
Nothing about the pump operation should change with EFI ,( unless you have butchered things )
The pump will run off the existing relay controlled by the ECM as it did with the V6 and
will run off the OP switch ( assuming you are installing the switch in the new engine )
Engine: 355
Axle/Gears: 3:43
Re: im stumped
I am installing the switch I'm lost as to which wire triggers the activation for key in run pos i have my hot and ground wires which am i missing?
Car: 82 Z28
Transmission: T400
Re: im stumped
Read
http://www.the12volt.com/relays/relays.asp
You should have 2 thick and 2 thinner wires on the relay connector.
The thick wires are power through the relay to the pump ,the thin wires operate the relay by going to ground through the relay coil .
You have the relay ground wire, what is left...?
Engine: 355
Axle/Gears: 3:43
Re: im stumped
I got the black wire red both thick brown leading into car and a green one with a white stripe I can hear the relay click back and forth but I cannot seem to get the fuel pump to prime and give me fuel up top at the bay it worked fine to begin with I got hot power heading to the pump via brown wire my green im assuming is for oil pressure switch? thats what triggered these on and off right?
