GPS Speed Sender
Old Oct 25, 2013 | 05:27 PM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
Transmission: 5-speed
GPS Speed Sender
Anyone use a gps speed sender? Not sure how but my mechanical vss's keep dying so i'm gonna upgrade. I'm thinking of using the dakota digital gps-50-1, just wondering if anyone has any input for me before i spend the money. Also, does the computer need any input from the vss (car is a standard) or can i just run the gps signal right to the speedometer?
Old Oct 26, 2013 | 01:20 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: GPS Speed Sender
https://www.thirdgen.org/forums/post...740-post4.html
Old Oct 29, 2013 | 04:41 PM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
Thank you. That brings another question, does the computer do anything with the signal conversion wise or can I run an 8000 pulse signal from the gps sender through what would be the vss buffer output to the ecm and still get the same reading on my gauge? If not, can I not use a gps sender? Thanks in advance
Old Oct 30, 2013 | 07:08 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
It says "
Offering a user selectable output of 4k, 8k, 16k PPM signals and a selectable signal type of a Sine Wave or Square Wave, the flexibility is endless. "
Your ECM requires a 4K VSS input so you should be right.
Select 4k , connect the GPS output to the ECM VSS terminals and then the ECM will output the speedo signal to the cluster as it does stock ?
Old Oct 30, 2013 | 04:16 PM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
Okay thank you. This may be a dumb question but I need to output an 8k signal for my aftermarket cluster, would it not be advisable to run an 8k signal to the ecm instead of 4k?
Old Oct 30, 2013 | 05:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Looks like you would need the memcal (prom) reprogrammed for that to work
https://www.thirdgen.org/forums/diy-...tor-730-a.html
Should PM member Tuned Performance ,he may be able to give you some advise on what works
https://www.thirdgen.org/forums/post...781-post4.html
Old Nov 19, 2013 | 05:47 PM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
I appreciate the help, but it looks like the solution is simpler than that. It appears that I can split the signal as needed using the sgi-5 box. The only problem I am having now is that I don't seem to be getting any signal out of the gps-50 box when hooked up either to the sgi-5 or directly to my speedometer. Not sure if anyone has successfully installed one of these but any help would be appreciated!
tommy z-28
Oct 6, 2015 10:58 PM
eustodp
Sep 20, 2015 05:09 PM
CatmanFS
Sep 19, 2015 09:00 AM
Ironhead38
Sep 7, 2015 02:26 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
