VSS pulse generator for '730 ecm
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Maybe I should post this here.
I need a VSS signal for my '730 ecm on a car that has a cable driven speedo (with no vss out at the cluster).
Will this work ?
http://www.summitracing.com/parts/DAK-SEN-01-4160/
I know the '730 can take a 4 or 8k PPM signal.
-- Joe
Will this work ?
-- Joe
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: VSS pulse generator for '730 ecm
I wasn't sure on the 8K input to the 730 but that is a good price for one.
I never tried setting the bin to 8000 to see what it would read (or is there a hardware setting?)
This is the one I use (4PAC) costs a bit more but can screw right onto the 700R4 so I went with it.
http://jagsthatrun.com/Pages/SpeedSe...eedometer.html
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'll have to re-read the schematic.
I could use any transmission combo eventually, so since the cable connection is the only thing that is fairly universal I need something generic.
-- Joe
Transmission: 5-speed/T-5
I've read recently of a guy using a Jeep VSS that is 8ppm, he set the bin accordingly and says it works fine.
You could also modify the speedo for an optical VSS, setting the bon accordingly for that and go that route. That's what I did in my Datsun, using $59.
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Axle/Gears: 3.27, I think
Check this place out. It even explains some of the different VSS.
http://www.jagsthatrun.com/Pages/Spe...eedometer.html
Car: check
Engine: check
Transmission: check
You mentioned using the '7730 ECM, but not the code mask. On $8D the optical (digital) input is 2K PPM. The magnetic input is 4K PPM. Only the magnetic input is programmable via the calibration for PPM rate.
You can patch the code to change the hard-coded optical constants for other PPM values. 8K PPM is do-able, but need to be within reason for the PPM pulse rates.
Also, the VSS pulse stream outputs are only available when using the magnetic input. This is true of all '7730 code masks as it is a hardware item.
The sensor you show appears to be Hall Effect, which is a digital output.
RBob.
RBob.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
RBob.
RBob.
Yeah I'm using $8D.
I need a VSS input.. somehow.
-- Joe
Also FYI, when I was building my bench I found that the Mag input is sine wave, optical is 5 V pulse.
For $35 and someone has made 8K work changing the bin I'd say go for it.
Jp
Jp
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
That unit is an AC sine wave so you should be good.
http://www.dakotadigital.com/PDF/SEN-01-1.PDF
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
A four-pulse (4000 pulses per mile) sine-wave (A.C. current or alternating current) signal is required by the 1990–1993 TPI, 1992–1993 LT1 engines, and 1990–1993 Camaro 3.1/3.4 V6 engines.
3.Part # 4PAC. Four-pulse sine wave.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
So If the ppm is switched to 8k in the bin, is there like a limit? If it uses a 8 bit integer, I'm thinking 114.8 mph?
-- Joe
-- Joe
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
im pretty sure there is a ppm limit to what the 7730 with 8D can use from a magnetic speed sensor.
im running a 700 from a pickup and have the 40 tooth relucter.
i tried to input the VSS directly to the ECM. it can set it up in the bin just fine, but it doesn't work very good.
i forget the exact speed, IIRC up around 55~60 the speed reading from the ECM starts dropping. the faster i go, the lower the speed the ECM reports.
as long as im running below where it starts acting up the ECM speed reading is fine.
if someone would do the math to find out what pulse per mile im getting, 2.42 rear gear, tires ~ 26 inches tall X 40, that should give you an ideal how high you can go.
That would make sense DENN why they have hardware dividers for the PPM. I would think 128 MPH would be the max but never looked into it.
Might have to fire up the bench and play with it this weekend.
These are set by three bits in the bin to configure the input.
Divide by 1 (ie for a 4000 ppm VSS)
Divide by 9 (36000 ppm VSS)
Divide by 7 (28000 ppm VSS)
Divide by 11 (44000 ppm VSS)
Divide by 6 (24000 ppm VSS)
Divide by 10 (40000 ppm VSS)
Divide by 8 (32000 ppm VSS)
Then there is the PPM setting in the bin as well.
Overall the 4PAC may be your best bet, I've never had a problem with mine since 04.
I could almost swear I've read higher MPH but can't find a log to prove it.
If that is true then that will be added to the list of code changes to work on next.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
But then again, when you consider how the MAF works on the '165 ECM, maybe it's nearly identical code. It would make sense that 255 counts at 8,000 PPM = 114.8 mph.
Too bad nobody could convert $8D into commented C code, so I could play too.
-- Joe
Car: check
Engine: check
Transmission: check
The output streams are for the speedometer and cruise control.
RBob.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
What is the "optical" VSS? Is that the output of the cable-fed in dash cluster on the camaros? Strictly speaking thirdgen fbodyapplication, is ALL of the electronic transmission mounted VSS senders magnetic?
-- Joe
Car: check
Engine: check
Transmission: check
RBob.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
When using the transmission mounted VSS, yes. And yes to 4K PPM from the VSS, and then 2K PPM to the ECM.
Optical is 2K PPM, used in the cable driven speedometers. This was also used in many other cars & trucks. It picked up the reflection of a bar (2-pole) in the speedometer head that spins with the cable.
All of the 3rd gen f-body trans mounted VSS are 4K PPM (4 pole) and magnetic.
RBob.
RBob.
You know, it's starting to get rough when I'm forgetting more than I'm learning.
With the number of magnetic speedo's I have I wonder if I couldn't make my own silly adapter.
-- Joe
im still using a DRAC from a chevy pickup to output the speed reading to the ECM, speedometer, and cruise control. im on my second DRAC, the first one quit after a couple of years. i think a short on the ground to power is what killed it.
JP, i've played around with the hardware dividers when i tried to use the truck VSS as the input to the ECM. i don't remember if changing them made any difference right now or not, my sometimers at work, LOL.
anesthes, im thinking out loud here, the 7730 can output a speed reading much higher than 128. before i got into chip tuning and still had the T350 trans with a speed cable, i cobbled together a speed sensor from a ford and put it inline on the speed cable. i used my snapon scanner and with the car up around 80 MPH the scanner was showing 160~170 MPH.
when i first put the 700 in i wired up the speed sensor and found that at around 15-20 MPH the ECM thought i was running 255 MPH. that lead to a locked TCC as soon as the trans went into second. thats one of the main reasons that i got into chip burning. turning off VATS in the chip was the other reason.
as for the ECM speed reading going lower than actual speed with the car above 55~60 and dropping even lower as speed increases when i had the truck magnetic speed sensor hooked to the ECM, i don't know. i always figured it either had to do with it over loading the speed buffer thats built into the 7730 or the signal strength too strong. i've mentioned it in a few posts here.
(light bulb moment) but now that you mention it, it makes sense that it has to do with the counts maxing out too soon
for turning on the light switch
for several years i've wanted to cut all but 4 teeth off a 40 tooth relucter and try it on my car, i just haven't gotten around to it yet.
for turning on the light switchfor several years i've wanted to cut all but 4 teeth off a 40 tooth relucter and try it on my car, i just haven't gotten around to it yet.
Elephantismo
Feb 13, 2019 12:51 AM
