Hatch Pull-down Assembly
Old Oct 29, 2013 | 09:26 PM
Logpet's Avatar
Car: '86 Trans Am
Engine: 305 5.0L TPI
Hello folks,
I've struggled to get my hatch pull-down assembly to work since I've owned the car for about a year now. I think I've finally figured out what is going on, but when I was testing my motor I shorted two wires together and they got a little toasty... Turns out I blew my fuse because I'm no longer getting any power to my motor. Easy fix, replace the fuse. However, I can't find the fuse. I've checked ALLDATA and my Pontiac books and the only direction to this location I have is, "Above the Fuse Block Taped to the I/P Harness." I've only pulled a bit of the underside of the dash apart and I've looked as far as I can above the fuse block and can't seem to see anything that looks like a fuse.
Has anyone had to replace this fuse? If so, where is it.
If its more trouble than its worth I may just run a new wire with an inline fuse and call it good.
Thanks for the help!
Old Oct 29, 2013 | 09:34 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Re: Hatch Pull-down Assembly
Look near the fuse block. It is in a black fuse holder, but is not actually in the fuse block/box. Just dangling there; doesn't look factory at all. Check my second photo here and look at the wiring harness.
Old Oct 29, 2013 | 09:38 PM
Logpet's Avatar
Car: '86 Trans Am
I'll check tomorrow to see if I can find it. If I replace it and still have issues, you know where I'm coming!
Old Oct 31, 2013 | 12:01 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Correct that the hatch pulldown fuse for the Firebirds is not in the fuse panel, but is in a separate single fuse holder. But that fuse holder WAS originally slid onto a dovetail on the outside of the fuse block. It can be slid off that dovetail though, so look first for it to be attached to the outside of the fuse block. If it is not there, look for the single fuse holder somewhere NEAR the fuse block, then attach it properly.
Lon
Old Nov 2, 2013 | 12:57 PM
89FormulaGirl's Avatar
Car: 1989 Pontiac Firebird Formula T-Top
Engine: 305 V8 5.0L
Transmission: Automatic
Do you know of where I could see how the pulldown assembly is hooked up to the rear wiring harness? I have a 1989 Formula, and the pulldown assembly looks exactly like this, but for the life of me I can't figure out how it attaches to the rear wiring harness.
Old Nov 2, 2013 | 01:23 PM
Joe Tag's Avatar
There is a blue wire for hot (connects to a red wire with a white tracer) and a ground screwed to the body. The white is unused in every car I have seen.
Old Nov 2, 2013 | 03:59 PM
lonsal's Avatar
That white wire plugs into a black with orange-stripe wire on late 89 to early 91 cars. It turns on/off the rear hatch light.
Lon
Old Nov 2, 2013 | 04:49 PM
Engine: 305 V8 5.0L
Thank you! I'm going to print this out and take it to the garage (no internet access there) and see what I can figure out. Working on a 1989 Formula total restoration, and want to get all the wiring working before the interior is done.
Old Nov 9, 2013 | 06:55 PM
Logpet's Avatar
Car: '86 Trans Am
Hey guys. I'm not exactly sure what I'm looking for. I have everything in your picture coming off my wiring harness. I see a connector like the one connected to the blue wire (bottom left of your picture). Is that the fuse? Is it built into that connector?
jrdturbo
Mar 31, 2016 02:58 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
gord327
Oct 3, 2015 01:25 PM
formula00ra
Sep 28, 2015 11:50 AM
