1991 Firebird Tail and side lights
Old Nov 2, 2013 | 02:38 PM
thanutz's Avatar
Hi all,
Looking for some help/advice and hope you can help. I have a 1991 Firebird 5L and recently the tail and side lights have stopped working. The brake, headlights and turn signals all work fine, including the motors popping up.
I found the wiring diagram at the bottom of this PM, which looks to be the right one.
First thing I checked was the tail light fuse, which is completely fine and has 12v running across it.
In the cargo area (rear), driver side, is a compartment that can be opened with a key. In there the wiring harness going to the tail lights is present. I checked this wire (BROWN), with the PARK light switch on, and it had no voltage across it.
So, as per the wiring diagram, something from the tail fuse to the brown wire is at fault.
Before I start pulling wires and switches out, any thoughts? I disconnected the harness at the back of my aftermarket stereo as I initially thought if there was a shared ground this may cause a problem. However given the brown wire is reading 0 volts I doubt this is the cause.
Could it be the switch even though the headlights work and pop?
Any advise would be appreciated.
Cheers,
Anil
Old Nov 4, 2013 | 04:59 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light Fright
Yes.
With the headlight switch in the Marker Lights On position, probe the
brown wire at the switch.
Is there power there?
If no, replace the switch.
Happy Racing!
I Never Fight In The Pits . . . . . . . . . My Pit Crew Does That For Me
jhawkeye
May 25, 2022 06:33 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Omega
Aug 10, 2015 12:46 PM
