Headlight malfunction
Old Nov 5, 2013 | 05:54 PM
JaredAdams97's Avatar
Car: 1982 Z28 Camaro
Engine: 5.7 L 350 V8
Transmission: Manual
Hey you guys so as of a couple of days ago I've come across a problem with one of my headlights. I have an 82' camaro, and as you know there are four headlights. The two low beam engage when the brights are off and all four engage when the brights are on. Well when Im on the low beam, only one headlight turns on. My first thought was that the other low beam was dead but when you engage the high beams, all four work great. Could there be an issue with a relay connecting to that one light?
Old Nov 5, 2013 | 10:01 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Headlight malfunction
The low beam that's dead needs to be replaced.
The low beam lamps have two filaments. One for the low beam and the other for the high beam. When you switch from low to high beams the filaments also switch.
See the diagram posted on this thread:
https://www.thirdgen.org/forums/elec...-question.html
Spyder_TheGamer
Oct 2, 2015 12:25 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
