Rear Hatch Pull-Down Motor
Old Nov 4, 2013 | 08:00 PM
jcoeracing97's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Pull-Down motor is stuck in the down position. There is minimal voltage to the luggage compartment lamp however it will not illuminate. Same goes for power into the motor itself: there is minimal voltage going in. The LID 15 amp fuse is good as well. All connections are clean and tight.
According to my 1992 GM Camaro service manual, all indications are pointing towards the inline relay that is to the left of the hatch pull-down motor.
Has anyone else experienced a similar issue and am I over-simplifying this problem...LOL?
Old Nov 11, 2013 | 04:47 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Voltageis Minimums
You either have the same voltage as the battery or you don’t (not sure what you are trying to say with “minimal voltage”)
In the Pull-Down Unit there is a reversing switch that causes it to come up, which you can access thru the opening where the latch is with a screwdriver or pencil.
Sometimes that switch needs to be flipped.
The reversing switch is about a half inch more towards the rear of the car than the latch is.
I forget if you need to flip it up or down but it will be obvious because it when it’s in one position it can only move in the other.
Happy Racing!
You Know You’ve “Arrived” When Bikers Rev Their Engines When They’re Beside You
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
